AZ-400 Exam
You are making use of Azure DevOps to configure Azure Pipelines for project, named PROJ-01.
You are preparing to use a version control system that allows for source code to be stored on a managed Windows server located on the company network.
Which of the following is the version control system you should use?
Github Enterprise
Bitbucket cloud
Github Professional
Git in Azure Repos
You need to consider the underlined segment to establish whether it is accurate.
When moving to Azure DevOps, JIRA must be replaced with the build pipelines Azure DevOps service.
Select No adjustment required if the underlined segment is accurate. If the underlined segment is inaccurate, select the accurate option.
No adjustment required.
repos
release pipelines
boards
You scan a Node.js application using WhiteSource Bolt.
The scan finds numerous libraries with invalid licenses, but are only used during development.
You have to make sure that only production dependencies are scanned by WhiteSource Bolt.
Which of the following is a command you should run?
npm edit
npm publish
npm install
npm update
You are currently defining a release strategy for an app, named APP-01.
The strategy should allow you to keep the time it takes to deploy new releases of the app to a minimum. The strategy should also allow you to roll back in the shortest time required.
Which of the following is the release strategy you should use?
Red/Black deployment
Rolling deployment
ג€Big Bangג€ deployment
Canary deployment
Your company hosts a web application in Azure, and makes use of Azure Pipelines for managing the build and release of the application.
When stakeholders report that system performance has been adversely affected by the most recent releases, you configure alerts in Azure Monitor.
You are informed that new releases must satisfy specified performance baseline conditions in the staging environment before they can be deployed to production.
You need to make sure that releases not satisfying the performance baseline are prevented from being deployed.
Which of the following actions should you take?
You should make use of a branch control check.
You should make use of an alert trigger.
You should make use of a gate.
You should make use of an approval check.
