AZ-400 Exam
You have an on-premises Bitbucket Server with a firewall configured to block inbound Internet traffic. The server is used for Git-based source control.
You intend to manage the build and release processes using Azure DevOps. This plan requires you to integrate Azure DevOps and Bitbucket.
Which of the following will allow for this integration? Answer by dragging the correct options from the list to the answer area.
You are currently developing a project for a client that will be managing work items via Azure DevOps.
You want to make sure that the work item process you use for the client allows for requirements, change requests, risks, and reviews to be tracked.
Which of the following is the option you would choose?
Basic
Agile
Scrum
CMMI
Note: The question is included in a number of questions that depicts the identical set-up. However, every question has a distinctive result. Establish if the solution satisfies the requirements.
You run the Register-AzureRmAutomationDscNode command in your company's environment.
You need to make sure that your company's test servers remain correctly configured, regardless of configuration drift.
Solution: You set the -ConfigurationMode parameter to ApplyOnly.
Does the solution meet the goal?
You need to consider the underlined segment to establish whether it is accurate.
To compile an Internet Information Services (IIS) web application that runs docker, you should use a Default build agent pool.
Select No adjustment required if the underlined segment is accurate. If the underlined segment is inaccurate, select the accurate option.
No adjustment required.
Hosted Windows Container
Hosted
Hosted macOS
Your company has an Azure DevOps environment that can only be accessed by Azure Active Directory users.
You are instructed to make sure that the Azure DevOps environment can only be accessed from devices connected to the company's on-premises network.
Which of the following actions should you take?
Assign the devices to a security group.
Create a GPO.
Configure Security in Project Settings from Azure DevOps.
Configure conditional access in Azure Active Directory.
