AZ-400 Exam
You are configuring project metrics for dashboards in Azure DevOps.
You need to configure a chart widget that measures the elapsed time to complete work items once they become active.
Which of the following is the widget you should use?
Cumulative Flow Diagram
Burnup
Cycle time
Burndown
You need to consider the underlined segment to establish whether it is accurate.
The Burnup widget measures the elapsed time from creation of work items to their completion.
Select No adjustment required if the underlined segment is accurate. If the underlined segment is inaccurate, select the accurate option.
No adjustment required.
Lead time
Test results trend
Burndown
You are making use of Azure DevOps manage build pipelines, and also deploy pipelines.
The development team is quite large, and is regularly added to.
You have been informed that the management of users and licenses must be automated when it can be.
Which of the following is a task that can't be automated?
Group membership changes
License assignment
Assigning entitlements
License procurement
You have been tasked with strengthening the security of your team's development process.
You need to suggest a security tool type for the Continuous Integration (CI) phase of the development process.
Which of the following is the option you would suggest?
Penetration testing
Static code analysis
Threat modeling
Dynamic code analysis
Your company is currently making use of Team Foundation Server 2013 (TFS 2013), but intend to migrate to Azure DevOps.
You have been tasked with supplying a migration approach that allows for the preservation of Team Foundation Version Control changesets dates, as well as the changes dates of work items revisions. The approach should also allow for the migration of all TFS artifacts, while keeping migration effort to a minimum.
You have suggested upgrading TFS to the most recent RTW release.
Which of the following should also be suggested?
Installing the TFS kava SDK
Using the TFS Database Import Service to perform the upgrade.
Upgrading PowerShell Core to the latest version.
Using the TFS Integration Platform to perform the upgrade.
