AZ-900 Exam
What are two characteristics of the public cloud? Each correct answer presents a complete solution.
dedicated hardware
unsecured connections
limited storage
metered pricing
self-service management
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
Your company plans to migrate all its data and resources to Azure.
The company's migration plan states that only Platform as a Service (PaaS) solutions must be used in Azure.
You need to deploy an Azure environment that meets the company migration plan.
Solution: You create an Azure App Service and Azure SQL databases.
Does this meet the goal?
Your company hosts an accounting application named App1 that is used by all the customers of the company.
App1 has low usage during the first three weeks of each month and very high usage during the last week of each month.
Which benefit of Azure Cloud Services supports cost management for this type of usage pattern?
high availability
high latency
elasticity
load balancing
You plan to migrate a web application to Azure. The web application is accessed by external users.
You need to recommend a cloud deployment solution to minimize the amount of administrative effort used to manage the web application.
What should you include in the recommendation?
Software as a Service (SaaS)
Infrastructure as a Service (IaaS)
Database as a Service (DaaS)
Which cloud deployment solution is used for Azure virtual machines and Azure SQL databases? To answer, select the appropriate options in the answer area.
