AZ-900 Exam
Your company has virtual machines (VMs) hosted in Microsoft Azure. The VMs are located in a single Azure virtual network named VNet1.
The company has users that work remotely. The remote workers require access to the VMs on VNet1.
You need to provide access for the remote workers.
What should you do?
Configure a Site-to-Site (S2S) VPN.
Configure a VNet-toVNet VPN.
Configure a Point-to-Site (P2S) VPN.
Configure DirectAccess on a Windows Server 2012 server VM.
Configure a Multi-Site VPN
The company would like to develop a cloud solution by making use of Azure Government. Azure Government can only be used by certain types of clients to develop cloud solutions.
Which of the following are the types of customers that can make use of Azure Government in this situation? Answer by dragging the correct option from the list to the answer area.
For each of the following statements, select Yes if the statement is true. Otherwise, select No.
To complete the sentence, select the appropriate option in the answer area.
You have an on-premises network that contains several servers.
You plan to migrate all the servers to Azure.
You need to recommend a solution to ensure that some of the servers are available if a single Azure data center goes offline for an extended period.
What should you include in the recommendation?
fault tolerance
elasticity
scalability
low latency
