AZ-600 Exam
You plan to deploy a highly available Azure App Service resource provider to an Azure Stack Hub integrated system.
You need to ensure that the App Service resource meets the prerequisites. The solution must minimize costs.
Which two resources should you deploy? Each correct answer presents part of the solution.
a highly available Microsoft SQL Server 2019 instance in the default provider subscription
a highly available file server in a dedicated user subscription
a highly available file server in the default provider subscription
a highly available Microsoft SQL Server 2019 instance in a dedicated user subscription
a single file server in the default provider subscription
a single Microsoft SQL Server 2019 instance in the default provider subscription
You have an Azure Stack Hub integrated system that is disconnected from the Internet. The integrated system is registered to an Azure Active Directory (Azure
AD) tenant named contoso.com.
You need to download the latest Ubuntu image for Azure Stack Hub Marketplace.
How should you complete the PowerShell script? To answer, drag the appropriate cmdlets to the correct targets. Each cmdlet may be used once, more than once, or not at all. You may need to drag and split the bar between panes to scroll to view content.
You have an Azure Stack Hub integrated system.
You need to delegate the management of offers to a user named User1.
Which three actions should you perform in a sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
You have an Azure Stack Hub integrated system that connects to the Internet. The integrated system uses an Enterprise Agreement (EA) for licensing.
You are creating an Azure Resource Manager template to generate a marketplace item for a virtual machine that runs Windows Server 2019 Datacenter and a custom application.
You need to ensure that Windows Server is licensed by using the bring-your-own-license model.
Solution: You add OsType: Windows to the Azure Resource Manager template.
Does this meet the goal?
HOTSPOT
You open the Resource providers blade for a user subscription as shown in the following exhibit.
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic.
