AZ-600 Exam
You deploy an Azure Stack Hub integrated system that contains an Azure App Service deployment. The integrated system uses an Azure Active Directory (Azure
AD) identity provider.
You need to provide users with the ability to deploy App Service web apps directly from their GitHub repositories.
Which three actions should you perform in sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
You have an Azure Stack Hub integrated system.
You plan to install the Event Hubs resource provider.
You purchase a public wildcard certificate that has a subject name of
*.eventhub.chicago.contoso.com. The path to the certificate is C:\Certificates\ssl.pfx.
You need to validate whether the certificate meets the requirements of Azure Event Hubs.
Which two actions should you perform? Each correct answer presents part of the solution.
Install the AzureStack.Identity PowerShell module
Rename the certificate file as Eventhub.pfx
Run the Invoke-AzsHubEventHubsCertificateValidation cmdlet
Run the Invoke-AzsHubDeploymentCertificateValidation cmdlet
Install the Microsoft.AzureStack.ReadinessChecker Powershell module
Convert the Ssl.pfx file to a CER file
You have an Azure Stack Hub integrated system that is disconnected from the Internet.
You need to make a new image available in Azure Stack Hub Marketplace in the disconnected environment.
From a computer that has Internet access, you download all the required tools.
Which four actions should you perform in sequence next? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
You have an Azure Stack Hub integrated system that uses an Azure Active Directory (Azure AD) identity provider.
You have a computer that runs Windows 10. You use the computer to manage the integrated system.
You create a custom marketplace item on the computer.
You need to publish the item to Azure Stack Hub Marketplace.
You create a storage account.
What should you create next?
a container that has a public access level of private
a file share that has the performance tier set to Hot
a container that has a public access level of blob
a file share that has the performance tier set to Transaction optimized
You have an Azure Stack Hub integrated system that connects to the Internet. The integrated system uses an Azure Active Directory (Azure AD) identity provider.
You need to update the Azure App Service resource provider.
Download the App Service installer to a computer that can connect to the Azure Stack Hub endpoints
Run appservice.exe as a local administrator
From the Updates blade of the administrator portal, select the Resource providers section
From the Updates blade of the administrator portal, select the infrastructure section
From the administrator portal, select the update, download the update, and then install the update
