AZ-120 Exam
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
After you answer a question in this section, you will NOT be able to return to it. As a result, these questions will not appear in the review screen.
You plan to migrate an SAP HANA instance to Azure.
You need to gather CPU metrics from the last 24 hours from the instance.
Solution: You query views from SAP HANA Studio.
Does this meet the goal?
A company named Contoso, Ltd. has users across the globe. Contoso is evaluating whether to migrate SAP to Azure.
The SAP environment runs on SUSE Linux Enterprise Server (SLES) servers and SAP HANA databases. The Suite on HANA database is 4 TB.
You need to recommend a migration solution to migrate SAP application servers and the SAP HANA databases. The solution must minimize downtime.
Which migration solutions should you recommend? To answer, select the appropriate options in the answer area.
You have an on-premises SAP environment hosted on VMware VSphere that uses Microsoft SQL Server as the database platform.
You plan to migrate the environment to Azure. The database platform will remain the same.
You need gather information to size the target Azure environment for the migration.
What should you use?
the SAP EarlyWatch Alert report
Azure Advisor
the SAP HANA sizing report
Azure Stack Edge
You have an existing SAP production landscape that uses SAP HANA databases.
You plan to migrate the landscape to Azure.
Which Azure virtual machine series will be Azure supported for the production SAP HANA database deployment?
F-Series
A-Series
M-Series
N-Series
You have an on-premises deployment of SAP HANA.
You plan to migrate the deployment to Azure.
You need to identify the following from the last six months:
✑ The number of active users
✑ The database performance
What should you do? To answer, select the appropriate options in the answer area.
