AZ-120 Exam
You have an SAP environment that is managed by using VMware vCenter.
You plan to migrate the SAP environment to Azure.
You need to gather information to identify which compute resources are required in Azure.
What should you use to gather the information?
Azure Migrate and SAP EarlyWatch Alert reports
Azure Site Recovery and SAP Quick Sizer
SAP Quick Sizer and SAP HANA system replication
Azure Site Recovery Deployment Planner and SAP HANA Cockpit
You plan to migrate an SAP ERP Central Component (SAP ECC) production system to Azure.
You are reviewing the SAP EarlyWatch Alert report for the system.
You need to recommend sizes for the Azure virtual machines that will host the system.
Which two sections of the report should you review? Each correct answer presents a complete solution.
Hardware Capacity
Patch Levels under SAP Software Configuration
Hardware Configuration under Landscape
Database and ABAP Load Optimization
Data Volume Management
You plan to migrate an SAP environment to Azure.
You need to recommend a solution to migrate the SAP application servers to Azure. The solution must minimize downtime and changes to the environments.
What should you include in the recommendation?
Azure Storage Explorer
Azure Import/Export service
AzCopy
Azure Site Recovery
You plan to migrate an on-premises SAP development system to Azure.
Before the migration, you need to check the usage of the source system hardware, such as CPU, memory, network, etc.
Which transaction should you run from SAP GUI?
SM51
DB01
DB12
OS07N
Your company has an SAP environment that contains the following components:
✑ SAP systems based on SAP HANA and SAP Adaptive Server Enterprise (SAP ASE) that run on SUSE Linux Enterprise Server 12 (SLES 12)
✑ Multiple SAP applications
The company plans to migrate all the applications to Azure.
You need to get a comprehensive list of all the applications that are part of the SAP environment.
What should you use?
the SAP license information
the SAP Solution Manager
the data volume management report
the network inventory and locations
