AWS Certified SysOps Administrator - Associate (SOA-C02)
A SysOps administrator is provisioning an Amazon Elastic File System (Amazon EFS) file system to provide shared storage across multiple
Amazon EC2 instances. The instances all exist in the same VPC across multiple Availability Zones. There are two instances in each Availability
Zone. The SysOps administrator must make the file system accessible to each instance with the lowest possible latency.
Create a mount target for the EFS file system in the VPC. Use the mount target to mount the file system on each of the instances.
Create a mount target for the EFS file system in one Availability Zone of the VPC. Use the mount target to mount the file system on the
instances in that Availability Zone. Share the directory with the other instances.
Create a mount target for each instance. Use each mount target to mount the EFS file system on each respective instance.
Create a mount target in each Availability Zone of the VPC. Use the mount target to mount the EFS file system on the instances in the
respective Availability Zone. Most Voted
A SysOps administrator has successfully deployed a VPC with an AWS CloudFormation template. The SysOps administrator wants to deploy the
same template across multiple accounts that are managed through AWS Organizations.
Which solution will meet this requirement with the LEAST operational overhead?
Assume the OrganizationAccountAccessRole IAM role from the management account. Deploy the template in each of the accounts.
Create an AWS Lambda function to assume a role in each account. Deploy the template by using the AWS CloudFormation CreateStack API
call.
Create an AWS Lambda function to query for a list of accounts. Deploy the template by using the AWS CloudFormation CreateStack API
call.
Use AWS CloudFormation StackSets from the management account to deploy the template in each of the accounts. Most Voted
#13 Multiple Choice
A company is running distributed computing software to manage a fleet of 20 Amazon EC2 instances for calculations. The fleet includes 2 control
nodes and 18 task nodes to run the calculations. Control nodes can automatically start the task nodes.
Currently, all the nodes run on demand. The control nodes must be available 24 hours a day, 7 days a week. The task nodes run for 4 hours each
day. A SysOps administrator needs to optimize the cost of this solution.
Which combination of actions will meet these requirements? (Choose two.)
Purchase EC2 Instance Savings Plans for the control nodes. Most Voted
Use Dedicated Hosts for the control nodes.
Use Reserved Instances for the task nodes.
Use Spot Instances for the control nodes. Use On-Demand Instances if there is no Spot availability.
Use Spot Instances for the task nodes. Use On-Demand Instances if there is no Spot availability. Most Voted
A company is supposed to receive a data file every hour in an Amazon S3 bucket. An S3 event notification invokes an AWS Lambda function each
time a file arrives. The function processes the data for use by an application.
The application team notices that sometimes the file does not arrive. The application team wants to receive a notification whenever the file does
not arrive.
What is the MOST operationally efficient solution that meets these requirements?
Add an S3 Lifecycle rule on the S3 bucket with a scope that is limited to objects that were created in the last hour. Configure another S3
event notification to be invoked by the lifecycle transition when the number of objects transitioned is zero. Publish a message to an Amazon
Simple Notification Service (Amazon SNS) topic to notify the application team.
Configure another S3 event notification to invoke a Lambda function that posts a message to an Amazon Simple Queue Service (Amazon
SQS) queue. Create an Amazon CloudWatch alarm to publish a message to an Amazon Simple Notification Service (Amazon SNS) topic to
notify the application team when the ApproximateAgeOfOldestMessage metric of the queue is greater than 1 hour.
Create an Amazon CloudWatch alarm to publish a message to an Amazon Simple Notification Service (Amazon SNS) topic to alert the
application team when the Invocations metric of the Lambda function is zero for an hour. Configure the alarm to treat missing data as
breaching. Most Voted
Create a new Lambda function to get the timestamp of the newest file in the S3 bucket. If the timestamp is more than 1 hour ago, publish a
message to an Amazon Simple Notification Service (Amazon SNS) topic to notify the application team. Create an Amazon EventBridge
(Amazon CloudWatch Events) rule to invoke the new function hourly.
A company recently acquired another corporation and all of that corporation's AWS accounts. A financial analyst needs the cost data from these
accounts. A
SysOps administrator uses Cost Explorer to generate cost and usage reports. The SysOps administrator notices that "No Tagkey" represents 20%
of the monthly cost.
What should the SysOps administrator do to tag the "No Tagkey" resources?
Add the accounts to AWS Organizations. Use a service control policy (SCP) to tag all the untagged resources.
Use an AWS Config rule to find the untagged resources. Set the remediation action to terminate the resources.
Use Cost Explorer to find and tag all the untagged resources.
Use Tag Editor to find and tag all the untagged resources. Most Voted
