AWS Certified SysOps Administrator - Associate (SOA-C02)
A company must ensure that any objects uploaded to an S3 bucket are encrypted.
Which of the following actions will meet this requirement? (Choose two.)
Implement AWS Shield to protect against unencrypted objects stored in S3 buckets.
Implement Object access control list (ACL) to deny unencrypted objects from being uploaded to the S3 bucket.
Implement Amazon S3 default encryption to make sure that any object being uploaded is encrypted before it is stored. Most Voted
Implement Amazon Inspector to inspect objects uploaded to the S3 bucket to make sure that they are encrypted.
Implement S3 bucket policies to deny unencrypted objects from being uploaded to the buckets. Most Voted
A company has a stateful web application that is hosted on Amazon EC2 instances in an Auto Scaling group. The instances run behind an
Application Load
Balancer (ALB) that has a single target group. The ALB is configured as the origin in an Amazon CloudFront distribution. Users are reporting
random logouts from the web application.
Which combination of actions should a SysOps administrator take to resolve this problem? (Choose two.)
Change to the least outstanding requests algorithm on the ALB target group.
Configure cookie forwarding in the CloudFront distribution cache behavior. Most Voted
Configure header forwarding in the CloudFront distribution cache behavior.
Enable group-level stickiness on the ALB listener rule.
Enable sticky sessions on the ALB target group. Most Voted
A company is running a serverless application on AWS Lambda. The application stores data in an Amazon RDS for MySQL DB instance. Usage has
steadily increased, and recently there have been numerous "too many connections" errors when the Lambda function attempts to connect to the
database. The company already has configured the database to use the maximum max_connections value that is possible.
What should a SysOps administrator do to resolve these errors?
Create a read replica of the database. Use Amazon Route 53 to create a weighted DNS record that contains both databases.
Use Amazon RDS Proxy to create a proxy. Update the connection string in the Lambda function. Most Voted
Increase the value in the max_connect_errors parameter in the parameter group that the database uses.
Update the Lambda function's reserved concurrency to a higher value.
A SysOps administrator is deploying an application on 10 Amazon EC2 instances. The application must be highly available. The instances must be
placed on distinct underlying hardware.
What should the SysOps administrator do to meet these requirements?
Launch the instances into a cluster placement group in a single AWS Region.
Launch the instances into a partition placement group in multiple AWS Regions.
Launch the instances into a spread placement group in multiple AWS Regions.
Launch the instances into a spread placement group in a single AWS Region. Most Voted
A SysOps administrator is troubleshooting an AWS CloudFormation template whereby multiple Amazon EC2 instances are being created. The
template is working in us-east-1, but it is failing in us-west-2 with the error code:
AMI [ami-12345678] does not exist
How should the Administrator ensure that the AWS CloudFormation template is working in every region?
Copy the source region's Amazon Machine Image (AMI) to the destination region and assign it the same ID.
Edit the AWS CloudFormation template to specify the region code as part of the fully qualified AMI ID.
Edit the AWS CloudFormation template to offer a drop-down list of all AMIs to the user by using the AWS::EC2::AMI::ImageID control.
Modify the AWS CloudFormation template by including the AMI IDs in the ג€Mappingsג€ section. Refer to the proper mapping within the
template for the proper AMI ID. Most Voted
