AWS Certified SysOps Administrator - Associate (SOA-C02)
A company has an infernal web application that runs on Amazon EC2 instances behind an Application Load Balancer. The instances run in an
Amazon EC2 Auto
Scaling group in a single Availability Zone. A SysOps administrator must make the application highly available.
Which action should the SysOps administrator take to meet this requirement?
Increase the maximum number of instances in the Auto Scaling group to meet the capacity that is required at peak usage.
Increase the minimum number of instances in the Auto Scaling group to meet the capacity that is required at peak usage.
Update the Auto Scaling group to launch new instances in a second Availability Zone in the same AWS Region. Most Voted
Update the Auto Scaling group to launch new instances in an Availability Zone in a second AWS Region.
A company hosts a website on multiple Amazon EC2 instances that run in an Auto Scaling group. Users are reporting slow responses during peak
times between
6 PM and 11 PM every weekend. A SysOps administrator must implement a solution to improve performance during these peak times.
What is the MOST operationally efficient solution that meets these requirements?
Create a scheduled Amazon EventBridge (Amazon CloudWatch Events) rule to invoke an AWS Lambda function to increase the desired
capacity before peak times.
Configure a scheduled scaling action with a recurrence option to change the desired capacity before and after peak times. Most Voted
Create a target tracking scaling policy to add more instances when memory utilization is above 70%.
Configure the cooldown period for the Auto Scaling group to modify desired capacity before and after peak times.
A company is running a website on Amazon EC2 instances behind an Application Load Balancer (ALB). The company configured an Amazon
CloudFront distribution and set the ALB as the origin. The company created an Amazon Route 53 CNAME record to send all traffic through the
CloudFront distribution. As an unintended side effect, mobile users are now being served the desktop version of the website.
Which action should a SysOps administrator take to resolve this issue?
Configure the CloudFront distribution behavior to forward the User-Agent header. Most Voted
Configure the CloudFront distribution origin settings. Add a User-Agent header to the list of origin custom headers.
Enable IPv6 on the ALB. Update the CloudFront distribution origin settings to use the dualstack endpoint.
Enable IPv6 on the CloudFront distribution. Update the Route 53 record to use the dualstack endpoint.
A SysOps administrator has enabled AWS CloudTrail in an AWS account. If CloudTrail is disabled, it must be re-enabled immediately.
What should the SysOps administrator do to meet these requirements WITHOUT writing custom code?
Add the AWS account to AWS Organizations. Enable CloudTrail in the management account.
Create an AWS Config rule that is invoked when CloudTrail configuration changes. Apply the AWS-ConfigureCloudTrailLogging automatic
remediation action. Most Voted
Create an AWS Config rule that is invoked when CloudTrail configuration changes. Configure the rule to invoke an AWS Lambda function to
enable CloudTrail.
Create an Amazon EventBridge (Amazon CloudWatch Event) hourly rule with a schedule pattern to run an AWS Systems Manager
Automation document to enable CloudTrail.
A company hosts its website on Amazon EC2 instances behind an Application Load Balancer. The company manages its DNS with Amazon Route
53, and wants to point its domain's zone apex to the website.
Which type of record should be used to meet these requirements?
An AAAA record for the domain's zone apex
An A record for the domain's zone apex
A CNAME record for the domain's zone apex
An alias record for the domain's zone apex Most Voted
