AWS Certified Data Engineer - Associate DEA-C01
A data engineer needs Amazon Athena queries to finish faster. The data engineer notices that all the files the Athena queries use are currently
stored in uncompressed .csv format. The data engineer also notices that users perform most queries by selecting a specific column.
Which solution will MOST speed up the Athena query performance?
Change the data format from .csv to JSON format. Apply Snappy compression.
Compress the .csv files by using Snappy compression.
Change the data format from .csv to Apache Parquet. Apply Snappy compression. Most Voted
Compress the .csv files by using gzip compression.
A manufacturing company collects sensor data from its factory floor to monitor and enhance operational efficiency. The company uses Amazon
Kinesis Data Streams to publish the data that the sensors collect to a data stream. Then Amazon Kinesis Data Firehose writes the data to an
Amazon S3 bucket.
The company needs to display a real-time view of operational efficiency on a large screen in the manufacturing facility.
Which solution will meet these requirements with the LOWEST latency?
Use Amazon Managed Service for Apache Flink (previously known as Amazon Kinesis Data Analytics) to process the sensor data. Use a
connector for Apache Flink to write data to an Amazon Timestream database. Use the Timestream database as a source to create a Grafana
dashboard. Most Voted
Configure the S3 bucket to send a notification to an AWS Lambda function when any new object is created. Use the Lambda function to
publish the data to Amazon Aurora. Use Aurora as a source to create an Amazon QuickSight dashboard.
Use Amazon Managed Service for Apache Flink (previously known as Amazon Kinesis Data Analytics) to process the sensor data. Create a
new Data Firehose delivery stream to publish data directly to an Amazon Timestream database. Use the Timestream database as a source to
Use AWS Glue bookmarks to read sensor data from the S3 bucket in real time. Publish the data to an Amazon Timestream database. Use
the Timestream database as a source to create a Grafana dashboard.
A company stores daily records of the financial performance of investment portfolios in .csv format in an Amazon S3 bucket. A data engineer
uses AWS Glue crawlers to crawl the S3 data.
The data engineer must make the S3 data accessible daily in the AWS Glue Data Catalog.
Create an IAM role that includes the AmazonS3FullAccess policy. Associate the role with the crawler. Specify the S3 bucket path of the
source data as the crawler's data store. Create a daily schedule to run the crawler. Configure the output destination to a new path in the
existing S3 bucket.
Create an IAM role that includes the AWSGlueServiceRole policy. Associate the role with the crawler. Specify the S3 bucket path of the
source data as the crawler's data store. Create a daily schedule to run the crawler. Specify a database name for the output. Most Voted
source data as the crawler's data store. Allocate data processing units (DPUs) to run the crawler every day. Specify a database name for the
output.
source data as the crawler's data store. Allocate data processing units (DPUs) to run the crawler every day. Configure the output destination to
a new path in the existing S3 bucket.
A company loads transaction data for each day into Amazon Redshift tables at the end of each day. The company wants to have the ability to
track which tables have been loaded and which tables still need to be loaded.
A data engineer wants to store the load statuses of Redshift tables in an Amazon DynamoDB table. The data engineer creates an AWS Lambda
function to publish the details of the load statuses to DynamoDB.
How should the data engineer invoke the Lambda function to write load statuses to the DynamoDB table?
Use a second Lambda function to invoke the first Lambda function based on Amazon CloudWatch events.
Use the Amazon Redshift Data API to publish an event to Amazon EventBridge. Configure an EventBridge rule to invoke the Lambda
function. Most Voted
Use the Amazon Redshift Data API to publish a message to an Amazon Simple Queue Service (Amazon SQS) queue. Configure the SQS
queue to invoke the Lambda function.
Use a second Lambda function to invoke the first Lambda function based on AWS CloudTrail events.
A data engineer needs to securely transfer 5 TB of data from an on-premises data center to an Amazon S3 bucket. Approximately 5% of the data
changes every day. Updates to the data need to be regularly proliferated to the S3 bucket. The data includes files that are in multiple formats. The
data engineer needs to automate the transfer process and must schedule the process to run periodically.
Which AWS service should the data engineer use to transfer the data in the MOST operationally efficient way?
AWS DataSync Most Voted
AWS Glue
AWS Direct Connect
Amazon S3 Transfer Acceleration
