AWS Certified Data Engineer - Associate DEA-C01
A company created an extract, transform, and load (ETL) data pipeline in AWS Glue. A data engineer must crawl a table that is in Microsoft SQL
Server. The data engineer needs to extract, transform, and load the output of the crawl to an Amazon S3 bucket. The data engineer also must
orchestrate the data pipeline.
Which AWS service or feature will meet these requirements MOST cost-effectively?
AWS Step Functions
AWS Glue workflows Most Voted
AWS Glue Studio
Amazon Managed Workflows for Apache Airflow (Amazon MWAA)
A financial services company stores financial data in Amazon Redshift. A data engineer wants to run real-time queries on the financial data to
support a web-based trading application. The data engineer wants to run the queries from within the trading application.
Which solution will meet these requirements with the LEAST operational overhead?
Establish WebSocket connections to Amazon Redshift.
Use the Amazon Redshift Data API. Most Voted
Set up Java Database Connectivity (JDBC) connections to Amazon Redshift.
Store frequently accessed data in Amazon S3. Use Amazon S3 Select to run the queries.
A company uses Amazon Athena for one-time queries against data that is in Amazon S3. The company has several use cases. The company must
implement permission controls to separate query processes and access to query history among users, teams, and applications that are in the
same AWS account.
Create an S3 bucket for each use case. Create an S3 bucket policy that grants permissions to appropriate individual IAM users. Apply the
S3 bucket policy to the S3 bucket.
Create an Athena workgroup for each use case. Apply tags to the workgroup. Create an IAM policy that uses the tags to apply appropriate
permissions to the workgroup. Most Voted
Create an IAM role for each use case. Assign appropriate permissions to the role for each use case. Associate the role with Athena.
Create an AWS Glue Data Catalog resource policy that grants permissions to appropriate individual IAM users for each use case. Apply the
resource policy to the specific tables that Athena uses.
A data engineer needs to schedule a workflow that runs a set of AWS Glue jobs every day. The data engineer does not require the Glue jobs to run
or finish at a specific time.
Which solution will run the Glue jobs in the MOST cost-effective way?
Choose the FLEX execution class in the Glue job properties. Most Voted
Use the Spot Instance type in Glue job properties.
Choose the STANDARD execution class in the Glue job properties.
Choose the latest version in the GlueVersion field in the Glue job properties.
A data engineer needs to create an AWS Lambda function that converts the format of data from .csv to Apache Parquet. The Lambda function
must run only if a user uploads a .csv file to an Amazon S3 bucket.
Create an S3 event notification that has an event type of s3:ObjectCreated:*. Use a filter rule to generate notifications only when the suffix
includes .csv. Set the Amazon Resource Name (ARN) of the Lambda function as the destination for the event notification. Most Voted
Create an S3 event notification that has an event type of s3:ObjectTagging:* for objects that have a tag set to .csv. Set the Amazon
Create an S3 event notification that has an event type of s3:*. Use a filter rule to generate notifications only when the suffix includes .csv.
includes .csv. Set an Amazon Simple Notification Service (Amazon SNS) topic as the destination for the event notification. Subscribe the
Lambda function to the SNS topic.
