Professional Cloud Architect Exam
You need to reduce the number of unplanned rollbacks of erroneous production deployments in your company's web hosting platform. Improvement to the QA/ Test processes accomplished an 80% reduction. Which additional two approaches can you take to further reduce the rollbacks? (Choose two.)
Introduce a green-blue deployment model
Replace the QA environment with canary releases
Fragment the monolithic platform into microservices
Reduce the platform's dependency on relational database systems
Replace the platform's relational database systems with a NoSQL database
To reduce costs, the Director of Engineering has required all developers to move their development infrastructure resources from on-premises virtual machines (VMs) to Google Cloud Platform. These resources go through multiple start/stop events during the day and require state to persist. You have been asked to design the process of running a development environment in Google Cloud while providing cost visibility to the finance department. Which two steps should you take? (Choose two.)
Use the - -no-auto-delete flag on all persistent disks and stop the VM
Use the - -auto-delete flag on all persistent disks and terminate the VM
Apply VM CPU utilization label and include it in the BigQuery billing export
Use Google BigQuery billing export and labels to associate cost to groups
Store all state into local SSD, snapshot the persistent disks, and terminate the VM
Store all state in Google Cloud Storage, snapshot the persistent disks, and terminate the VM
Your company wants to track whether someone is present in a meeting room reserved for a scheduled meeting. There are 1000 meeting rooms across 5 offices on 3 continents. Each room is equipped with a motion sensor that reports its status every second. The data from the motion detector includes only a sensor ID and several different discrete items of information. Analysts will use this data, together with information about account owners and office locations. Which database type should you use?
Flat file
NoSQL
Relational
Blobstore
You set up an autoscaling instance group to serve web traffic for an upcoming launch. After configuring the instance group as a backend service to an HTTP(S) load balancer, you notice that virtual machine (VM) instances are being terminated and re-launched every minute. The instances do not have a public IP address. You have verified the appropriate web response is coming from each instance using the curl command. You want to ensure the backend is configured correctly. What should you do?
Ensure that a firewall rules exists to allow source traffic on HTTP/HTTPS to reach the load balancer.
Assign a public IP to each instance and configure a firewall rule to allow the load balancer to reach the instance public IP.
Ensure that a firewall rule exists to allow load balancer health checks to reach the instances in the instance group.
Create a tag on each instance with the name of the load balancer. Configure a firewall rule with the name of the load balancer as the source and the instance tag as the destination.
You write a Python script to connect to Google BigQuery from a Google Compute Engine virtual machine. The script is printing errors that it cannot connect to BigQuery. What should you do to fix the script?
Install the latest BigQuery API client library for Python
Run your script on a new virtual machine with the BigQuery access scope enabled
Create a new service account with BigQuery access and execute your script with that user
Install the bq component for gcloud with the command gcloud components install bq.
