AZ-140 Exam
You have an on-premises network.
All users have computers that run Windows 10 Pro.
You plan to deploy Azure Virtual Desktop to meet the department requirements shown in the following table.
You need to recommend licenses for the departments. The solution must minimize costs.
Which license should you recommend for each department? To answer, select the appropriate options in the answer area.
Your company has 60,000 users.
You plan to deploy Azure Virtual Desktop.
You need to recommend a storage solution for the FSLogix profile containers. The solution must provide the highest possible IOPS and the lowest latency desktop experience.
What should you recommend?
Azure Data Lake Storage
Azure NetApp Files
Azure Blob Storage Premium
Azure Files Standard
Your company has a single office and has 40 employees.
You are planning an Azure Virtual Desktop deployment. The estimated user workloads are shown in the following table.
Half the users of each workload type work from home. All the users who work from home do NOT establish a VPN connection to the office.
Approximately how much bandwidth is needed between the office and Azure to support the planned workloads?
9.5 Mbps
55 Mbps
110 Mbps
220 Mbps
Your network contains an on-premises Active Directory domain that syncs to an Azure Active Directory (Azure AD) tenant. The domain contains the domain controllers shown in the following table.
The DNS servers are configured to forward requests to an external DNS service.
You create a new virtual network named VNET2 that is peered to VNET1 and has gateway transit enabled.
You plan to implement an Azure Virtual Desktop host pool in VNET2. The session hosts will be joined to the Active Directory domain.
You need to configure DNS to meet the following requirements:
✑ Ensure that Azure Virtual Desktop users can resolve on-premises servers and Azure resources.
✑ Ensure that azure Virtual Desktop remains operational if a DNS server fails.
✑ Minimize administrative effort.
What should you configure?
the DNS settings of VNET2 to use Server2 and Server1
the DNS settings of VNET2 to use the Azure DNS service
the DNS settings of the virtual machines to use Server2 and Server1
the DNS settings of the virtual machines to use the Azure DNS service
You have an Azure subscription that contains a hybrid Azure Active Directory (Azure AD) tenant and two domain-joined Azure virtual machines. The virtual machines run Windows Server 2019 and contain managed disks.
You plan to deploy an Azure Virtual Desktop host pool that will use a Storage Spaces Direct Scale-Out File Server to host user profiles.
You need to ensure that the virtual machines can host the Storage Spaces Direct deployment. The solution must meet the following requirements:
✑ Ensure that the user profiles are available if a single server fails.
What should you do? To answer, select the appropriate options in the answer area.
