AZ-104 Exam
Your company has virtual machines (VMs) hosted in Microsoft Azure. The VMs are located in a single Azure virtual network named VNet1.
The company has users that work remotely. The remote workers require access to the VMs on VNet1.
You need to provide access for the remote workers.
What should you do?
Configure a Site-to-Site (S2S) VPN.
Configure a VNet-toVNet VPN.
Configure a Point-to-Site (P2S) VPN.
Configure DirectAccess on a Windows Server 2012 server VM.
Configure a Multi-Site VPN
Your company has two on-premises servers named SRV01 and SRV02. Developers have created an application that runs on SRV01. The application calls a service on SRV02 by IP address.
You plan to migrate the application on Azure virtual machines (VMs). You have configured two VMs on a single subnet in an Azure virtual network.
You need to configure the two VMs with static internal IP addresses.
What should you do?
Run the New-AzureRMVMConfig PowerShell cmdlet.
Run the Set-AzureSubnet PowerShell cmdlet.
Modify the VM properties in the Azure Management Portal.
Modify the IP properties in Windows Network and Sharing Center.
Run the Set-AzureStaticVNetIP PowerShell cmdlet.
Your company has an Azure Active Directory (Azure AD) subscription.
You need to deploy five virtual machines (VMs) to your company's virtual network subnet.
The VMs will each have both a public and private IP address. Inbound and outbound security rules for all of these virtual machines must be identical.
Which of the following is the least amount of network interfaces needed for this configuration?
Your company's Azure subscription includes Azure virtual machines (VMs) that run Windows Server 2016.
One of the VMs is backed up every day using Azure Backup Instant Restore.
When the VM becomes infected with data encrypting ransomware, you decide to recover the VM's files.
Which of the following is TRUE in this scenario?
You can only recover the files to the infected VM.
You can recover the files to any VM within the company's subscription.
You can only recover the files to a new VM.
You will not be able to recover the files.
You administer a solution in Azure that is currently having performance issues.
You need to find the cause of the performance issues pertaining to metrics on the Azure infrastructure.
Which of the following is the tool you should use?
Azure Traffic Analytics
Azure Monitor
Azure Activity Log
Azure Advisor
