AWS Certified DevOps Engineer - Professional DOP-C02
#6 Multiple Choice
A company must encrypt all AMIs that the company shares across accounts. A DevOps engineer has access to a source account where an
unencrypted custom AMI has been built. The DevOps engineer also has access to a target account where an Amazon EC2 Auto Scaling group will
launch EC2 instances from the AMI. The DevOps engineer must share the AMI with the target account.
The company has created an AWS Key Management Service (AWS KMS) key in the source account.
Which additional steps should the DevOps engineer perform to meet the requirements? (Choose three.)
In the source account, copy the unencrypted AMI to an encrypted AMI. Specify the KMS key in the copy action. Most Voted
In the source account, copy the unencrypted AMI to an encrypted AMI. Specify the default Amazon Elastic Block Store (Amazon EBS)
encryption key in the copy action.
In the source account, create a KMS grant that delegates permissions to the Auto Scaling group service-linked role in the target account.
In the source account, modify the key policy to give the target account permissions to create a grant. In the target account, create a KMS
grant that delegates permissions to the Auto Scaling group service-linked role. Most Voted
In the source account, share the unencrypted AMI with the target account.
In the source account, share the encrypted AMI with the target account. Most Voted
#7 Multiple Choice
A company uses AWS CodePipeline pipelines to automate releases of its application A typical pipeline consists of three stages build, test, and
deployment. The company has been using a separate AWS CodeBuild project to run scripts for each stage. However, the company now wants to
use AWS CodeDeploy to handle the deployment stage of the pipelines.
The company has packaged the application as an RPM package and must deploy the application to a fleet of Amazon EC2 instances. The EC2
instances are in an EC2 Auto Scaling group and are launched from a common AMI.
Which combination of steps should a DevOps engineer perform to meet these requirements? (Choose two.)
Create a new version of the common AMI with the CodeDeploy agent installed. Update the IAM role of the EC2 instances to allow access to
CodeDeploy. Most Voted
Create a new version of the common AMI with the CodeDeploy agent installed. Create an AppSpec file that contains application deployment
scripts and grants access to CodeDeploy.
Create an application in CodeDeploy. Configure an in-place deployment type. Specify the Auto Scaling group as the deployment target. Add
a step to the CodePipeline pipeline to use EC2 Image Builder to create a new AMI. Configure CodeDeploy to deploy the newly created AMI.
Update the CodePipeline pipeline to use the CodeDeploy action to deploy the application. Most Voted
Create an application in CodeDeploy. Configure an in-place deployment type. Specify the EC2 instances that are launched from the common
AMI as the deployment target. Update the CodePipeline pipeline to use the CodeDeploy action to deploy the application.
#8 Multiple Choice
A company’s security team requires that all external Application Load Balancers (ALBs) and Amazon API Gateway APIs are associated with AWS
WAF web ACLs. The company has hundreds of AWS accounts, all of which are included in a single organization in AWS Organizations. The
company has configured AWS Config for the organization. During an audit, the company finds some externally facing ALBs that are not associated
with AWS WAF web ACLs.
Which combination of steps should a DevOps engineer take to prevent future violations? (Choose two.)
Delegate AWS Firewall Manager to a security account. Most Voted
Delegate Amazon GuardDuty to a security account.
Create an AWS Firewall Manager policy to attach AWS WAF web ACLs to any newly created ALBs and API Gateway APIs. Most Voted
Create an Amazon GuardDuty policy to attach AWS WAF web ACLs to any newly created ALBs and API Gateway APIs.
Configure an AWS Config managed rule to attach AWS WAF web ACLs to any newly created ALBs and API Gateway APIs.
A company uses AWS Key Management Service (AWS KMS) keys and manual key rotation to meet regulatory compliance requirements. The
security team wants to be notified when any keys have not been rotated after 90 days.
Which solution will accomplish this?
Configure AWS KMS to publish to an Amazon Simple Notification Service (Amazon SNS) topic when keys are more than 90 days old.
Configure an Amazon EventBridge event to launch an AWS Lambda function to call the AWS Trusted Advisor API and publish to an Amazon
Simple Notification Service (Amazon SNS) topic.
Develop an AWS Config custom rule that publishes to an Amazon Simple Notification Service (Amazon SNS) topic when keys are more than
90 days old. Most Voted
Configure AWS Security Hub to publish to an Amazon Simple Notification Service (Amazon SNS) topic when keys are more than 90 days old.
A security review has identified that an AWS CodeBuild project is downloading a database population script from an Amazon S3 bucket using an
unauthenticated request. The security team does not allow unauthenticated requests to S3 buckets for this project.
How can this issue be corrected in the MOST secure manner?
Add the bucket name to the AllowedBuckets section of the CodeBuild project settings. Update the build spec to use the AWS CLI to
download the database population script.
Modify the S3 bucket settings to enable HTTPS basic authentication and specify a token. Update the build spec to use cURL to pass the
token and download the database population script.
Remove unauthenticated access from the S3 bucket with a bucket policy. Modify the service role for the CodeBuild project to include
Amazon S3 access. Use the AWS CLI to download the database population script. Most Voted
Remove unauthenticated access from the S3 bucket with a bucket policy. Use the AWS CLI to download the database population script
using an IAM access key and a secret access key.
