AWS Certified DevOps Engineer - Professional DOP-C02
A company has a mobile application that makes HTTP API calls to an Application Load Balancer (ALB). The ALB routes requests to an AWS
Lambda function. Many different versions of the application are in use at any given time, including versions that are in testing by a subset of
users. The version of the application is defined in the user-agent header that is sent with all requests to the API.
After a series of recent changes to the API, the company has observed issues with the application. The company needs to gather a metric for
each API operation by response code for each version of the application that is in use. A DevOps engineer has modified the Lambda function to
extract the API operation name, version information from the user-agent header and response code.
Which additional set of actions should the DevOps engineer take to gather the required metrics?
Modify the Lambda function to write the API operation name, response code, and version number as a log line to an Amazon CloudWatch
Logs log group. Configure a CloudWatch Logs metric filter that increments a metric for each API operation name. Specify response code and
application version as dimensions for the metric.
Logs log group. Configure a CloudWatch Logs Insights query to populate CloudWatch metrics from the log lines. Specify response code and
Configure the ALB access logs to write to an Amazon CloudWatch Logs log group. Modify the Lambda function to respond to the ALB with
the API operation name, response code, and version number as response metadata. Configure a CloudWatch Logs metric filter that increments
a metric for each API operation name. Specify response code and application version as dimensions for the metric.
Configure AWS X-Ray integration on the Lambda function. Modify the Lambda function to create an X-Ray subsegment with the API
operation name, response code, and version number. Configure X-Ray insights to extract an aggregated metric for each API operation name
and to publish the metric to Amazon CloudWatch. Specify response code and application version as dimensions for the metric.
A company provides an application to customers. The application has an Amazon API Gateway REST API that invokes an AWS Lambda function.
On initialization, the Lambda function loads a large amount of data from an Amazon DynamoDB table. The data load process results in long cold-
start times of 8-10 seconds. The DynamoDB table has DynamoDB Accelerator (DAX) configured.
Customers report that the application intermittently takes a long time to respond to requests. The application receives thousands of requests
throughout the day. In the middle of the day, the application experiences 10 times more requests than at any other time of the day. Near the end of
the day, the application's request volume decreases to 10% of its normal total.
A DevOps engineer needs to reduce the latency of the Lambda function at all times of the day.
Configure provisioned concurrency on the Lambda function with a concurrency value of 1. Delete the DAX cluster for the DynamoDB table.
Configure reserved concurrency on the Lambda function with a concurrency value of 0.
Configure provisioned concurrency on the Lambda function. Configure AWS Application Auto Scaling on the Lambda function with
provisioned concurrency values set to a minimum of 1 and a maximum of 100. Most Voted
Configure reserved concurrency on the Lambda function. Configure AWS Application Auto Scaling on the API Gateway API with a reserved
concurrency maximum value of 100.
A company is adopting AWS CodeDeploy to automate its application deployments for a Java-Apache Tomcat application with an Apache
Webserver. The development team started with a proof of concept, created a deployment group for a developer environment, and performed
functional tests within the application. After completion, the team will create additional deployment groups for staging and production.
The current log level is configured within the Apache settings, but the team wants to change this configuration dynamically when the deployment
occurs, so that they can set different log level configurations depending on the deployment group without having a different application revision
for each group.
How can these requirements be met with the LEAST management overhead and without requiring different script versions for each deployment
group?
Tag the Amazon EC2 instances depending on the deployment group. Then place a script into the application revision that calls the
metadata service and the EC2 API to identify which deployment group the instance is part of. Use this information to configure the log level
settings. Reference the script as part of the AfterInstall lifecycle hook in the appspec.yml file.
Create a script that uses the CodeDeploy environment variable DEPLOYMENT_GROUP_ NAME to identify which deployment group the
instance is part of. Use this information to configure the log level settings. Reference this script as part of the BeforeInstall lifecycle hook in
the appspec.yml file. Most Voted
Create a CodeDeploy custom environment variable for each environment. Then place a script into the application revision that checks this
environment variable to identify which deployment group the instance is part of. Use this information to configure the log level settings.
Reference this script as part of the ValidateService lifecycle hook in the appspec.yml file.
Create a script that uses the CodeDeploy environment variable DEPLOYMENT_GROUP_ID to identify which deployment group the instance is
part of to configure the log level settings. Reference this script as part of the Install lifecycle hook in the appspec.yml file.
A company requires its developers to tag all Amazon Elastic Block Store (Amazon EBS) volumes in an account to indicate a desired backup
frequency. This requirement Includes EBS volumes that do not require backups. The company uses custom tags named Backup_Frequency that
have values of none, dally, or weekly that correspond to the desired backup frequency. An audit finds that developers are occasionally not tagging
the EBS volumes.
A DevOps engineer needs to ensure that all EBS volumes always have the Backup_Frequency tag so that the company can perform backups at
least weekly unless a different value is specified.
Set up AWS Config in the account. Create a custom rule that returns a compliance failure for all Amazon EC2 resources that do not have a
Backup Frequency tag applied. Configure a remediation action that uses a custom AWS Systems Manager Automation runbook to apply the
Backup_Frequency tag with a value of weekly.
Set up AWS Config in the account. Use a managed rule that returns a compliance failure for EC2::Volume resources that do not have a
Backup_Frequency tag with a value of weekly. Most Voted
Turn on AWS CloudTrail in the account. Create an Amazon EventBridge rule that reacts to EBS CreateVolume events. Configure a custom
AWS Systems Manager Automation runbook to apply the Backup_Frequency tag with a value of weekly. Specify the runbook as the target of
the rule.
Turn on AWS CloudTrail in the account. Create an Amazon EventBridge rule that reacts to EBS CreateVolume events or EBS ModifyVolume
events. Configure a custom AWS Systems Manager Automation runbook to apply the Backup_Frequency tag with a value of weekly. Specify
the runbook as the target of the rule.
A company is using an Amazon Aurora cluster as the data store for its application. The Aurora cluster is configured with a single DB instance. The
application performs read and write operations on the database by using the cluster's instance endpoint.
The company has scheduled an update to be applied to the cluster during an upcoming maintenance window. The cluster must remain available
with the least possible interruption during the maintenance window.
What should a DevOps engineer do to meet these requirements?
Add a reader instance to the Aurora cluster. Update the application to use the Aurora cluster endpoint for write operations. Update the
Aurora cluster's reader endpoint for reads. Most Voted
Add a reader instance to the Aurora cluster. Create a custom ANY endpoint for the cluster. Update the application to use the Aurora
cluster's custom ANY endpoint for read and write operations.
Turn on the Multi-AZ option on the Aurora cluster. Update the application to use the Aurora cluster endpoint for write operations. Update the
Aurora cluster’s reader endpoint for reads.
Turn on the Multi-AZ option on the Aurora cluster. Create a custom ANY endpoint for the cluster. Update the application to use the Aurora
