AWS Certified AI Practitioner AIF-C01
A company uses Amazon SageMaker for its ML pipeline in a production environment. The company has large input data sizes up to 1 GB and
processing times up to 1 hour. The company needs near real-time latency.
Which SageMaker inference option meets these requirements?
Real-time inference
Serverless inference
Asynchronous inference Most Voted
Batch transform
A company is using domain-specific models. The company wants to avoid creating new models from the beginning. The company instead wants
to adapt pre-trained models to create models for new, related tasks.
Which ML strategy meets these requirements?
Increase the number of epochs.
Use transfer learning. Most Voted
Decrease the number of epochs.
Use unsupervised learning.
A company is building a solution to generate images for protective eyewear. The solution must have high accuracy and must minimize the risk of
incorrect annotations.
Human-in-the-loop validation by using Amazon SageMaker Ground Truth Plus Most Voted
Data augmentation by using an Amazon Bedrock knowledge base
Image recognition by using Amazon Rekognition
Data summarization by using Amazon QuickSight Q
A company wants to create a chatbot by using a foundation model (FM) on Amazon Bedrock. The FM needs to access encrypted data that is
stored in an Amazon S3 bucket. The data is encrypted with Amazon S3 managed keys (SSE-S3).
The FM encounters a failure when attempting to access the S3 bucket data.
Ensure that the role that Amazon Bedrock assumes has permission to decrypt data with the correct encryption key. Most Voted
Set the access permissions for the S3 buckets to allow public access to enable access over the internet.
Use prompt engineering techniques to tell the model to look for information in Amazon S3.
Ensure that the S3 data does not contain sensitive information.
A company wants to use language models to create an application for inference on edge devices. The inference must have the lowest latency
possible.
Deploy optimized small language models (SLMs) on edge devices. Most Voted
Deploy optimized large language models (LLMs) on edge devices.
Incorporate a centralized small language model (SLM) API for asynchronous communication with edge devices.
Incorporate a centralized large language model (LLM) API for asynchronous communication with edge devices.
