AWS Certified Advanced Networking - Specialty ANS-C01
#6 Multiple Choice
A software-as-a-service (SaaS) provider hosts its solution on Amazon EC2 instances within a VPC in the AWS Cloud. All of the provider's
customers also have their environments in the AWS Cloud.
A recent design meeting revealed that the customers have IP address overlap with the provider's AWS deployment. The customers have stated
that they will not share their internal IP addresses and that they do not want to connect to the provider's SaaS service over the internet.
Which combination of steps is part of a solution that meets these requirements? (Choose two.)
Deploy the SaaS service endpoint behind a Network Load Balancer. Most Voted
Configure an endpoint service, and grant the customers permission to create a connection to the endpoint service. Most Voted
Deploy the SaaS service endpoint behind an Application Load Balancer.
Configure a VPC peering connection to the customer VPCs. Route traffic through NAT gateways.
Deploy an AWS Transit Gateway, and connect the SaaS VPC to it. Share the transit gateway with the customers. Configure routing on the
transit gateway.
#7 Multiple Choice
A network engineer is designing the architecture for a healthcare company's workload that is moving to the AWS Cloud. All data to and from the
on-premises environment must be encrypted in transit. All traffic also must be inspected in the cloud before the traffic is allowed to leave the
cloud and travel to the on-premises environment or to the internet.
The company will expose components of the workload to the internet so that patients can reserve appointments. The architecture must secure
these components and protect them against DDoS attacks. The architecture also must provide protection against financial liability for services
that scale out during a DDoS event.
Which combination of steps should the network engineer take to meet all these requirements for the workload? (Choose three.)
Use Traffic Mirroring to copy all traffic to a fleet of traffic capture appliances.
Set up AWS WAF on all network components.
Configure an AWS Lambda function to create Deny rules in security groups to block malicious IP addresses.
Use AWS Direct Connect with MACsec support for connectivity to the cloud. Most Voted
Use Gateway Load Balancers to insert third-party firewalls for inline traffic inspection. Most Voted
Configure AWS Shield Advanced and ensure that it is configured on all public assets. Most Voted
#8 Multiple Choice
A retail company is running its service on AWS. The company’s architecture includes Application Load Balancers (ALBs) in public subnets. The
ALB target groups are configured to send traffic to backend Amazon EC2 instances in private subnets. These backend EC2 instances can call
externally hosted services over the internet by using a NAT gateway.
The company has noticed in its billing that NAT gateway usage has increased significantly. A network engineer needs to find out the source of this
increased usage.
Which options can the network engineer use to investigate the traffic through the NAT gateway? (Choose two.)
Enable VPC flow logs on the NAT gateway's elastic network interface. Publish the logs to a log group in Amazon CloudWatch Logs. Use
CloudWatch Logs Insights to query and analyze the logs. Most Voted
Enable NAT gateway access logs. Publish the logs to a log group in Amazon CloudWatch Logs. Use CloudWatch Logs Insights to query and
analyze the logs.
Configure Traffic Mirroring on the NAT gateway's elastic network interface. Send the traffic to an additional EC2 instance. Use tools such as
tcpdump and Wireshark to query and analyze the mirrored traffic.
Enable VPC flow logs on the NAT gateway's elastic network interface. Publish the logs to an Amazon S3 bucket. Create a custom table for
the S3 bucket in Amazon Athena to describe the log structure. Use Athena to query and analyze the logs. Most Voted
Enable NAT gateway access logs. Publish the logs to an Amazon S3 bucket. Create a custom table for the S3 bucket in Amazon Athena to
A banking company is successfully operating its public mobile banking stack on AWS. The mobile banking stack is deployed in a VPC that
includes private subnets and public subnets. The company is using IPv4 networking and has not deployed or supported IPv6 in the environment.
The company has decided to adopt a third-party service provider's API and must integrate the API with the existing environment. The service
provider’s API requires the use of IPv6.
A network engineer must turn on IPv6 connectivity for the existing workload that is deployed in a private subnet. The company does not want to
permit IPv6 traffic from the public internet and mandates that the company's servers must initiate all IPv6 connectivity. The network engineer
turns on IPv6 in the VPC and in the private subnets.
Create an internet gateway and a NAT gateway in the VPC. Add a route to the existing subnet route tables to point IPv6 traffic to the NAT
gateway.
Create an internet gateway and a NAT instance in the VPC. Add a route to the existing subnet route tables to point IPv6 traffic to the NAT
instance.
Create an egress-only Internet gateway in the VPAdd a route to the existing subnet route tables to point IPv6 traffic to the egress-only
internet gateway. Most Voted
Create an egress-only internet gateway in the VPC. Configure a security group that denies all inbound traffic. Associate the security group
with the egress-only internet gateway.
A company has deployed an AWS Network Firewall firewall into a VPC. A network engineer needs to implement a solution to deliver Network
Firewall flow logs to the company’s Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster in the shortest possible time.
Create an Amazon S3 bucket. Create an AWS Lambda function to load logs into the Amazon OpenSearch Service (Amazon Elasticsearch
Service) cluster. Enable Amazon Simple Notification Service (Amazon SNS) notifications on the S3 bucket to invoke the Lambda function.
Configure flow logs for the firewall. Set the S3 bucket as the destination.
Create an Amazon Kinesis Data Firehose delivery stream that includes the Amazon OpenSearch Service (Amazon Elasticsearch Service)
cluster as the destination. Configure flow logs for the firewall Set the Kinesis Data Firehose delivery stream as the destination for the Network
Firewall flow logs. Most Voted
Configure flow logs for the firewall. Set the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster as the destination for the
Network Firewall flow logs.
Create an Amazon Kinesis data stream that includes the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster as the
destination. Configure flow logs for the firewall. Set the Kinesis data stream as the destination for the Network Firewall flow logs.
