Associate Cloud Engineer Exam
You need a dynamic way of provisioning VMs on Compute Engine. The exact specifications will be in a dedicated configuration file. You want to follow Google's recommended practices. Which method should you use?
Deployment Manager
Cloud Composer
Managed Instance Group
Unmanaged Instance Group
You have a Dockerfile that you need to deploy on Kubernetes Engine. What should you do?
Use kubectl app deploy .
Use gcloud app deploy .
Create a docker image from the Dockerfile and upload it to Container Registry. Create a Deployment YAML file to point to that image. Use kubectl to create the deployment with that file.
Create a docker image from the Dockerfile and upload it to Cloud Storage. Create a Deployment YAML file to point to that image. Use kubectl to create the deployment with that file.
Your development team needs a new Jenkins server for their project. You need to deploy the server using the fewest steps possible. What should you do?
Download and deploy the Jenkins Java WAR to App Engine Standard.
Create a new Compute Engine instance and install Jenkins through the command line interface.
Create a Kubernetes cluster on Compute Engine and create a deployment with the Jenkins Docker image.
Use GCP Marketplace to launch the Jenkins solution.
You need to update a deployment in Deployment Manager without any resource downtime in the deployment. Which command should you use?
gcloud deployment-manager deployments create --config
gcloud deployment-manager deployments update --config
gcloud deployment-manager resources create --config
gcloud deployment-manager resources update --config
You need to run an important query in BigQuery but expect it to return a lot of records. You want to find out how much it will cost to run the query. You are using on-demand pricing. What should you do?
Arrange to switch to Flat-Rate pricing for this query, then move back to on-demand.
Use the command line to run a dry run query to estimate the number of bytes read. Then convert that bytes estimate to dollars using the Pricing Calculator.
Use the command line to run a dry run query to estimate the number of bytes returned. Then convert that bytes estimate to dollars using the Pricing Calculator.
Run a select count (*) to get an idea of how many records your query will look through. Then convert that number of rows to dollars using the Pricing Calculator.
