AZ-720 Exam
A company uses Azure Site Recovery (ASR) for a VMWare environment that includes the following virtual machines (VMs):
The company reports that they are unable to configure all of the servers for replication.
You need to evaluate the servers and server roles to determine which servers can be protected.
Which server can you protect by using ASR?
VM2
VM1
VM3
VM4
A company uses Azure Site Recovery (ASR) to replicate and recover Azure virtual machines (VM) between Azure regions.
An administrator receives the following warning from ASR about a VM that uses P10 disks: Data change rate beyond supported limits
You add OS Disk Write Bytes/Sec and Data Disk Write Bytes/Sec to the list of metrics for monitoring. You discover that the VM consistently has a data churn of greater than 8 MB/s but less than 10 MB/s.
You need to resolve the issue.
What should you do?
Uninstall the Volume Shadow Copy Service (VSS) Provider service.
Upgrade the target storage disk.
Use AzCopy to upload data to a cache storage account.
Create a network service endpoint in a virtual network.
A company has an on-premises application server that runs in System Center Virtual Machine Manager (SCVMM). The company configures Azure Site Recovery.
An administrator at the company reports that they receive an error message. The error message indicates that there are replication issues.
You need to troubleshoot the issue.
Which log should you review?
SCVMM debug log
Network Security Group flow log
Network Watcher diagnostic log
Azure Monitor log
A company uses Azure Backup Agent to back up specific files and folders from an on-premises virtual machine (VM).
An administrator reports that the backup job is transferring files slowly. You determine that the backup job is verifying changes in directories by scanning the entire volume.
You need to determine the state of the backup job.
In which state will the backups occur? To answer, select the appropriate options in the answer area.
A company migrates an on-premises Windows virtual machine (VM) to Azure. An administrator enables backups for the VM by using the Azure portal.
The company reports that the Azure VM backup job is failing.
What should you do?
Install the VM guest agent with administrative permissions.
Create a new manual backup in Backup center.
Run chkdsk on the VM.
Enable replication and create a recovery plan for the backup vault.
Configure the retention range of the current backup policy for the VM.
