AWS Certified Solutions Architect - Professional SAP-C02
A company needs to architect a hybrid DNS solution. This solution will use an Amazon Route 53 private hosted zone for the domain
cloud.example.com for the resources stored within VPCs.
The company has the following DNS resolution requirements:
On-premises systems should be able to resolve and connect to cloud.example.com.
All VPCs should be able to resolve cloud.example.com.
There is already an AWS Direct Connect connection between the on-premises corporate network and AWS Transit Gateway.
Which architecture should the company use to meet these requirements with the HIGHEST performance?
Associate the private hosted zone to all the VPCs. Create a Route 53 inbound resolver in the shared services VPC. Attach all VPCs to the
transit gateway and create forwarding rules in the on-premises DNS server for cloud.example.com that point to the inbound resolver.
Associate the private hosted zone to all the VPCs. Deploy an Amazon EC2 conditional forwarder in the shared services VPC. Attach all
VPCs to the transit gateway and create forwarding rules in the on-premises DNS server for cloud.example.com that point to the conditional
forwarder.
Associate the private hosted zone to the shared services VPCreate a Route 53 outbound resolver in the shared services VPAttach all VPCs
to the transit gateway and create forwarding rules in the on-premises DNS server for cloud.example.com that point to the outbound resolver.
Associate the private hosted zone to the shared services VPC. Create a Route 53 inbound resolver in the shared services VPC. Attach the
shared services VPC to the transit gateway and create forwarding rules in the on-premises DNS server for cloud.example.com that point to the
inbound resolver.
A company is providing weather data over a REST-based API to several customers. The API is hosted by Amazon API Gateway and is integrated
with different AWS Lambda functions for each API operation. The company uses Amazon Route 53 for DNS and has created a resource record of
weather.example.com. The company stores data for the API in Amazon DynamoDB tables. The company needs a solution that will give the API the
ability to fail over to a different AWS Region.
Deploy a new set of Lambda functions in a new Region. Update the API Gateway API to use an edge-optimized API endpoint with Lambda
functions from both Regions as targets. Convert the DynamoDB tables to global tables.
Deploy a new API Gateway API and Lambda functions in another Region. Change the Route 53 DNS record to a multivalue answer. Add both
API Gateway APIs to the answer. Enable target health monitoring. Convert the DynamoDB tables to global tables.
Deploy a new API Gateway API and Lambda functions in another Region. Change the Route 53 DNS record to a failover record. Enable
target health monitoring. Convert the DynamoDB tables to global tables. Most Voted
Deploy a new API Gateway API in a new Region. Change the Lambda functions to global functions. Change the Route 53 DNS record to a
multivalue answer. Add both API Gateway APIs to the answer. Enable target health monitoring. Convert the DynamoDB tables to global tables.
A company uses AWS Organizations with a single OU named Production to manage multiple accounts. All accounts are members of the
Production OU. Administrators use deny list SCPs in the root of the organization to manage access to restricted services.
The company recently acquired a new business unit and invited the new unit’s existing AWS account to the organization. Once onboarded, the
administrators of the new business unit discovered that they are not able to update existing AWS Config rules to meet the company’s policies.
Which option will allow administrators to make changes and continue to enforce the current policies without introducing additional long-term
maintenance?
Remove the organization’s root SCPs that limit access to AWS Config. Create AWS Service Catalog products for the company’s standard
AWS Config rules and deploy them throughout the organization, including the new account.
Create a temporary OU named Onboarding for the new account. Apply an SCP to the Onboarding OU to allow AWS Config actions. Move the
new account to the Production OU when adjustments to AWS Config are complete.
Convert the organization’s root SCPs from deny list SCPs to allow list SCPs to allow the required services only. Temporarily apply an SCP to
the organization’s root that allows AWS Config actions for principals only in the new account.
organization’s root SCP to the Production OU. Move the new account to the Production OU when adjustments to AWS Config are complete.
A company is running a two-tier web-based application in an on-premises data center. The application layer consists of a single server running a
stateful application. The application connects to a PostgreSQL database running on a separate server. The application’s user base is expected to
grow significantly, so the company is migrating the application and database to AWS. The solution will use Amazon Aurora PostgreSQL, Amazon
EC2 Auto Scaling, and Elastic Load Balancing.
Which solution will provide a consistent user experience that will allow the application and database tiers to scale?
Enable Aurora Auto Scaling for Aurora Replicas. Use a Network Load Balancer with the least outstanding requests routing algorithm and
sticky sessions enabled.
Enable Aurora Auto Scaling for Aurora writers. Use an Application Load Balancer with the round robin routing algorithm and sticky sessions
enabled.
Enable Aurora Auto Scaling for Aurora Replicas. Use an Application Load Balancer with the round robin routing and sticky sessions
enabled. Most Voted
Enable Aurora Scaling for Aurora writers. Use a Network Load Balancer with the least outstanding requests routing algorithm and sticky
sessions enabled.
A company uses a service to collect metadata from applications that the company hosts on premises. Consumer devices such as TVs and
internet radios access the applications. Many older devices do not support certain HTTP headers and exhibit errors when these headers are
present in responses. The company has configured an on-premises load balancer to remove the unsupported headers from responses sent to
older devices, which the company identified by the User-Agent headers.
The company wants to migrate the service to AWS, adopt serverless technologies, and retain the ability to support the older devices. The company
has already migrated the applications into a set of AWS Lambda functions.
Create an Amazon CloudFront distribution for the metadata service. Create an Application Load Balancer (ALB). Configure the CloudFront
distribution to forward requests to the ALB. Configure the ALB to invoke the correct Lambda function for each type of request. Create a
CloudFront function to remove the problematic headers based on the value of the User-Agent header. Most Voted
Create an Amazon API Gateway REST API for the metadata service. Configure API Gateway to invoke the correct Lambda function for each
type of request. Modify the default gateway responses to remove the problematic headers based on the value of the User-Agent header.
Create an Amazon API Gateway HTTP API for the metadata service. Configure API Gateway to invoke the correct Lambda function for each
type of request. Create a response mapping template to remove the problematic headers based on the value of the User-Agent. Associate the
response data mapping with the HTTP API.
Lambda@Edge function that will remove the problematic headers in response to viewer requests based on the value of the User-Agent header.
